Home > Maintenance & Mods (L405) > l405 electric steps
Andy66
l405 electric steps
since buying my l405 2013 4.4 autobiography the passenger auto step comes out less and less, no problem with driver step, any idea whats causing the problem
Post #710735 31st Jan 2025 9:48pm
Simply dirt crud and probably rust on the pivot points in the brackets but also importantly on the drive shaft in/from the motor. They have a relatively weak torque threshold for stopping working (safety device if obstructions encountered) so it doesn't take much crud to trigger the sensor and stop. Requires regular cleaning and greasing at the critical points - simple as. Mike - MPx
Post #710741 31st Jan 2025 11:16pm
Gremlin500
Hi Andy, welcome to FFRR.com,
Use the SEARCH facility above for term “deployable steps” -loads of info on this very common issue, and how to fix, -temporarily. I’m afraid it’s an ongoing maintenance issue!
Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #710742 31st Jan 2025 11:17pm
