Home > For Sale & Wanted > [Wanted] Oil filter leaf spring
ashtrucker
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Looking for the leaf spring which sits under the oil filter on a 4.4 tdv8 anybody recently changes there oil cooler and not put it in the bin yet 2012 Westminster 4.4 tdv8
Post #710541 29th Jan 2025 3:50pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
There is a second hand housing here which may have the part you want. Expensive way but not sure they would be sold as a seperate part.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #710545 29th Jan 2025 4:41pm
ashtrucker
Thanks that’s my last option but hoping I can get one another way 2012 Westminster 4.4 tdv8
Post #710546 29th Jan 2025 4:46pm
ashtrucker
Post #710547 29th Jan 2025 4:48pm
comports
Hi Ash
I have the spring but not the rubber bung that goes with it.
You are welcome to the spring and there is a forum member called Butcher that can supply the bungs. I believe they come in bags of 5 and around around the £40 mark. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #710650 30th Jan 2025 11:36pm
ashtrucker
Looks like my bung on my old one is ok so should be able to swap over it’s the square end on mine that’s broken 2012 Westminster 4.4 tdv8
Post #710664 31st Jan 2025 5:23am
