![]() | Home > Technical (L322) > Rear wishbone alignment bolts seized |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2604 ![]() ![]() |
I had to cut one of mine off with a 5" thin cut-off saw because the bolt had rusted in the metal centre of the bush which had broken free of the outer part of the bush. I cut the bolt between the bush and the bracket on the other side to the bolt head. |
Apps Member Since: 24 Dec 2024 Location: Leeds Posts: 23 ![]() ![]() ![]() |
Thanks for your reply. I think that's what I will have to get done as I don't want to put new tyres on until I can get the alignment 100% |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
same really, i had to cut mine off. nothing else for it just make sure you dont damage the tabs Its actually a sport |
