Home > Maintenance & Mods (L405) > Steering Wheel buttons
See update a few posts below..... Don't buy these
At 80,000 miles and 10 years old my steering wheel buttons were starting to show their age and had gone a bit "sticky" as they do...
To be fare I wasn't that taken by the later looking all black buttons but after seeing how much new original ones are I thought I would give it a go.
I found a store on AliExpress who were adamant theirs worked so £87 later a pair were on their way, only took a few days to arrive well boxed...
You have to remove the flappy paddles, one T20 torx screw, then remove a screw under that, again a T20, you then have to pop the airbag off but you don't have to disconnect it so you can leave the battery connected, then just pull off the old ones, which take quite a pull, remove the multi plug and you are done. As they say, fitting is a reversal. They came with a little jumper that you fit if the left one doesn't behave, mine needed the jumper.
Anyway all fitted and I have to say they work spot on and look fine...
I read of some stopping the paddles working and other issues, well these work just as they should and do feel nicer than the old ones..
I can recommend these if someone wants to change theirs.
Before
Fitted and all black with the ignition off..
Lit up, heated steering wheel is on...
Wide angle shot
This is a link to the ones I bought....
https://www.aliexpress.com/item/1005008402535103.html
I'm very pleased with them, especially at that price... Thumbs Up Pete
Post #710145 25th Jan 2025 3:34pm
mjdronfield
Looks good Pete… and you are famous on their site
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #710156 25th Jan 2025 4:27pm
i have the OE version and they are much better than the old type..
as always, nice job Pete.. Thumbs Up ... - .- -.
Post #710161 25th Jan 2025 4:46pm
When you find something that cheap and it looks good and works then I think they need praise... Thumbs Up Pete
Post #710162 25th Jan 2025 4:46pm
Thanks Stan, don't know what these are like compared to the "proper" ones but they are very tactile, and cheap as chips.... Thumbs Up Pete
Post #710163 25th Jan 2025 4:48pm
Right then, don't buy these, had them 2 weeks and first off the buttons worked spot on, I've done a fare few miles and I use the ACC a lot and now the ACC buttons on the right only work about 70% of the time you press them. The others are fine still but I guess they will fail soon..
They will be going back..... Sad Pete
Post #711400 8th Feb 2025 9:35pm
