![]() | Home > Technical (L322) > Gas discharge 30 seconds after parking |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1450 ![]() ![]() |
If I remember correctly the suspension draws air in and vents air out through an air dryer filter thing … which is all in the compressor unit under the boot floor.. when it parks up it normally does a quick level by letting down the sides to get level , this venting the air. … so is that where you are hearing it from? V8 or else ... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
The above mentioned compressor is inside under the boot floor… in the spare wheel well under the wheel.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Mine does it every time
