Rear brake slide pin length | |
Good afternoon,
I ordered a set of rear brake slider pins, TRW ST1730, from Autodoc, which listed the 2012 L322 as a compatible car. The dust guards were included. The TRW (ZF) website also lists it as compatible.
Again, from Autodoc, at the same time, I ordered a Frenkit 745814 rear calliper rebuild kit—pistons, seals, etc. Included are the pins and rubber dust guards. Autodoc lists the parts to fit the 2012 L322 with TRW callipers. The Frenkit website lists it as compatible.
Comparing the pins, diameter and length they are quite different. The dust guards too are very different.
Can anyone confirm, what length the pins should be? The Frenkit is far more chunkier at around 75mm long and 10mm diameter.
I am changing the pins fitted back in 2023 because the rear brakes are squeaking and I have a funny feeling the wrong pins were used due to this confusion and wrongly trusting suppliers, so comparing the new ones to the current ones fitted is no point.
Thanks!
 | Click image to enlarge |
2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
