![]() | Home > Technical (L405) > Battery Replaced but still no EV |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 798 ![]() ![]() ![]() |
What is the temperatura outside? Below 5 degrees Celsius, the ICE engine always kicks in.
AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 172 ![]() ![]() |
The temperature was around 8-9 Celsius last I tried so not too cold. Am also running the car with the HVAC off to remove the HV Heater variable. I’m also getting zero DTCs when I’m scanning.
When you press the EV switch what happens? Do you get the grayed out EV logo on the dashboard?
Yes I get the EV light on the button itself and it appears in the instrument display greyed out.
Sorry I can't be of help, I'm actually worried about the cause, if no error is displayed. Maybe try to disconnect the main 12V battery and reconnect? It worked once for me, after the car stayed in a parking lot for 1 month and at start myriads of errors popped out... I carry a wrench in the door pocket ever since... |
Thanks for trying adara.
That's great news. A helpful member (aljo) said at some point that his PHEV does this "every time jlr connect the diagnostic equipment , goes back too normal after 40-50 miles". |
