![]() | Home > Technical (L322) > M62 WATER PUMP |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
The fattie has (again) deveoped a leak from the water pump's base, where the body mates with the block, just under the bottom left bolt. Coolant seeps slowly forming a drop and finds its way down onto the PAS pump, then onto the undertray and eventually on the driveway overnight. Running the engine for a couple mnutes is enough to make the leak stop, as the metals expand. So the leak only happens with a stone-cold engine.
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 208 ![]() ![]() |
Last year I replaced the water pump as mine failed (seized and took the belts out with it), and while I was changing it thought I'd change to the lower temperature thermostat, as I wanted to lower the temperature (my OEM pump had a problem with the electric sensor too).
Thanks
So after the entire week with my daily work commute and temperatures dropping as low as 2-3C overnight, I'm glad to observe no more leaks. Coolant level has also been stable. I really hope that was all... |
An update ro wrap this up:
Duplicate; pls delete |
