Home > Technical (L322) > Heater fan not working for first ten minutes….
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
2012 TDV8.
The heater fan is not coming at start up when selected, either auto, manual, max a/c or defrost. After about ten minutes, it behaves normally. The heater itself appears to be fine as the parking heat works normally too.
Any fixes please? 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #708018 1st Jan 2025 5:05pm
mjdronfield
Normally, both my L322s wouldn’t blow air out if you have selected a warmer temp and the water isn’t there yet…. That said, max defrost always put the air out….. so not sure….
Only ever had it on Auto…. Never tried in manual fan with engine cold, so all this might be a red herring……
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #708035 1st Jan 2025 7:23pm
JW911
Having reviewed some of the recent threads and with my fan showing remarkable consistency, maybe this is actually a thing. I played around today and had the same results.
My car had a full (latest LR from Solihull) software update a few months ago. Not sure many 322s will have had this so realistically, I’m probably most interested in what early generation L405s do…. 2012 4.4 TDV8 Westminster
Post #708212 3rd Jan 2025 8:18pm
mjdronfield
So if you select a colder temperature does the fan come on earlier or always 10 min?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #708214 3rd Jan 2025 8:36pm
JW911
No idea. It’s -3. Laughing 2012 4.4 TDV8 Westminster
Post #708217 3rd Jan 2025 9:11pm
