Home > Technical (L322) > L322 2010 4.4 heater blower cutting out
RichardHL3222010
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Galway Green
Hello
Recently changed the FSR and a new battery on my car as it was draining and going flat
Now the heater blower works fine temperature wise and AC but it cuts out the moment you hit medium speed so won’t go to high at all
It works again after turning off for a few seconds
Even on slow speed it maybe runs for 30 seconds to a minute then cuts out
Has anyone experienced this? I can’t see anyone sharing the same experience but similar ones point to the blower motor or fuses
Post #707729 28th Dec 2024 9:29am
mjdronfield
Can’t help directly, but if it works consistently again if you put the old one back it can’t be a fuse, if you are able to do that.
Could be faulty new FSR? But def sounds strange.
Disturbed connection?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #707736 28th Dec 2024 11:12am
RichardHL3222010
Update fixed back in January. The issue was a faulty FSR - a cheapy at £20z got a £60 and all hunky dory
Post #712973 27th Feb 2025 8:58pm
