Home > Technical (L322) > 2012 l322 suspension fault |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
Not answering your question, but if you can get the car up to normal height then pull the 20A main suspenison fuse from the rear fuse panel then it won't be able to lower.
22nd Dec 2024 8:10am |
joejoe300 Member Since: 22 Dec 2024 Location: Nottinghamshire Posts: 9 |
I have it says c1ao4-21 left front height sensor |
22nd Dec 2024 8:35am |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 67 |
did you replace with the correct sensor, the 2012 have adaptive and use all 6 pins and the earlier ones only use 3 of the 6 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
22nd Dec 2024 8:54am |
Yes I replaced it with 2 new ones and still get the same fault code |
22nd Dec 2024 9:05am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 869 |
I seem to recall it’s possible to fit the height sensors upside down without it being obvious - may be worth double checking depending on who fitted them. Jonathan
22nd Dec 2024 9:30am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3241 |
As said it's easy to fit them the wrong way. Also the wiring is poorly protected ( typical of the whole car) so it may be this is the fault and not the actual sensor. 2012 TDV8 Vogue (L322) |
22nd Dec 2024 9:55am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
As JayGee said the wiring is a weak point, IIRC they sell a part lead with a new plug and tails which will need fitting... Pete
22nd Dec 2024 10:09am |
Hi all just had a look at the voltage at the top of the dynamic strut tops on the front both read 0.88 volts
22nd Dec 2024 11:36am |
Right front voltage looks unusual but check the voltages at access height and off road height so you can confirm they are all changing and in the same direction. Does your diagnostic tool have a suspension calibration function like the GAP IID tool? 2012 TDV8 Vogue (L322) |
22nd Dec 2024 11:45am |
Hi I have done the calibration but the car wont go up on the suspension keep getting dynamic suspension fault on the display and left front level sensor fault on code reader |
22nd Dec 2024 11:50am |
will it go to access height? 2012 TDV8 Vogue (L322) |
22nd Dec 2024 12:10pm |
It dont seem to want to go up at all |
22nd Dec 2024 12:13pm |
Access height is down 2012 TDV8 Vogue (L322) |
22nd Dec 2024 12:54pm |
Just checked my height sensor voltages and the front right also seems to have a low value compared to the rest so this may just be a quirk of the system as the actual heights are within 10mm of each other all round.
22nd Dec 2024 2:43pm |
