![]() | Home > Maintenance & Mods (L405) > What under the wheel arch liners? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
The body work shell will generally be fine behind the liners. You get corrosion where steel parts are bolted to the shell , such as the sub frames. (Read the threads about ACE pipes to see some examples).
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 116 ![]() ![]() ![]() |
I think it's worth checking everything behind the liners for corrosion, but particularly the electrical ground points in the front wheel arches. |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 177 ![]() ![]() ![]() |
The fuel tank guard / cradle will probably be rusty but unfortunately they rust from the inside out. Expensive to replace so people remove it, get it shot blasted, then ( if there's anything left ) repair, paint and replace. I've given mine a couple of coats of Lanoguard to make it look better till I get round to doing it properly.
