Home > General (L460 2022) > Should "Guardian Mode" be switched on?
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
I've just noticed that "Guardian Mode" (whatever that is) in the "Remote App" for my L460 is switched off. Should this be turned on to improve / increase security?
Post #707153 17th Dec 2024 6:43pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Hi Allister, I think you switch it on manually when the vehicle is at a bit more risk than normal, IE leaving it at the airport, parked up for a few days on the street, you are on holiday etc ... Its a heightened level of monitoring but I think you loose some of the remote app functionality whilst it is on. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #707154 17th Dec 2024 7:31pm
aja500
Thank you for answering that JEZ.... I'm currently overnight in Sheffield and forgot to put my Disklok in the car.
The car is in a hotel car park and although there is barriers, it is making me slightly nervous, as it is more vulnerable than normal.
So this I suspect is the perfect situation for Guardian Mode - Will switch it on overnight now.
Many thanks once again and hope all is well with you.
Best,
Allister
Post #707163 17th Dec 2024 10:19pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
It should send you a notification if the doors open, even with a key (or if they grab the key signal to unlock/open) First time FFRR owner
Post #707164 17th Dec 2024 10:34pm
aja500
That's good to know, thank you Thumbs Up Thumbs Up
Post #707165 17th Dec 2024 10:40pm
