Home > Technical (L460) > SDV8 Top end oil leak
IRBails
Australia
OK no leak from oil cooler but very small leak into valley and I can't quite work out where it is coming from. No noticeable oil use but I like perfection if i can achieve. I think it my be rocker cover and am wondering if this is common , and more to the point how hard to correct.
I have changed out the oil cooler, preventative maintenance, also the turbo feed O rings , no leaks there.
I am after suggestions , in reality leak at present not bad enough to warrant a big job but if an easy fix I will do.
Post #707121 17th Dec 2024 11:28am
please confirm what year/model you have so i can move this to the appropriate section.. ... - .- -.
Post #707126 17th Dec 2024 1:08pm
