Home > Maintenance & Mods (L405) > Quiescent Relay Box
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Quiescent Relay Box
Does anyone know where the Quiescent Relay Box is, and what it does?
Doing some research, I believe it has something to do with battery drain and switching off components that are no longer required.
The IID says I have a fault code "B1412-96 (2F) Quiescent Relay Box - component internal failure", although the car doesn't seem to be experiencing any problems. If it is an easy replacement, it might be worth finding a 2nd hand replacement and swapping it out. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #706094 4th Dec 2024 4:37pm
Kot
Load space RH side take panel off where fusebox and the 2nd battery located.
https://www.fullfatrr.com/gallery/albums/u...eplace.pdf
https://www.fullfatrr.com/gallery/albums/u...earJB7.pdf 2018 SE SDV8 4.4 Byron Blue
Post #706097 4th Dec 2024 5:24pm
Zebedee
Thanks for those...
I've also just found a TOPIx notification - SSM72286: B1412-96 Flagged in the Gateway Module which seems to imply that nothing is needed.
 Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #706101 4th Dec 2024 6:52pm
Kot
Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #706117 4th Dec 2024 10:42pm
Mundach1968
Australia 2017 Range Rover Vogue SE SDV8 Santorini Black
Same issue on my MY17 SDV8. Identified like you via IID Tool. Thanks for the Post - I'll ignore it,
Post #709052 14th Jan 2025 12:59am
