Home > General > Facelifted RR
Facelifted RR
I was reading thru Autocar and came across a couple of points on the new FFRR.
The facelifted RANGE ROVER is all about moving the car up market further and making it look "more formal" according to LAND ROVER'S design boss Gerry McGovern.
But the next RANGE ROVER is going to take that ethos even further.
"It's going to look so expensive that you think you won't be able to afford it" says McGovern,,,,,,,,,,,,,,,,,
ALSO .......
Sat-Nav Could go google Land Rover says it has already future - proofed the new Generation Range Rovers and Discovery models by fitting a 40GB hard drive into the car's infotainment system ....
So if they are trying to make the FFRR move up into the "bentley" stakes , and are trying to make the new D4 the Range Rover , where does that leave the RRS ........ THE UPMARKET FREELANDER Rolling with laughter Rolling with laughter
Post #5215 27th Apr 2009 8:14pm
