Home > General (L405) > Cost to get a new key ? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
A good locksmith will take the module out, read it with their programmer and can create you another key. It'll be £200-250 for that kind of job.
7th Nov 2024 8:33pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 377 |
I believe you can programme a key yourself with an IID tool.
8th Nov 2024 4:54pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 395 |
yes i can confirm that the gap tool will program a key even when from a different range rover (done two) takes about 2-3 min |
8th Nov 2024 7:29pm |
maxbasscat Member Since: 11 Jun 2016 Location: South Cambs Posts: 28 |
I have searched for this outfit and little comes up. Have you more information that you can share? |
8th Nov 2024 9:04pm |
https://www.facebook.com/londonautolocksmiths 2015 Range Rover Autobiography 4.4 SDV8 |
8th Nov 2024 10:05pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
I can only report from the German area: If you want a new key for the Range Rover from 2015 onwards, the control unit has to be reprogrammed and not even the clever car thieves from Lithuania can do that so easily, even my long-time key supplier couldn't do it. The key itself may only cost 50 euros with a transponder, but it's of no use. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
23rd Nov 2024 6:56pm |
Thanks I will investigate and report back |
24th Nov 2024 8:44pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I got an unprogrammed Key from Dan at Duckworhs (he's no longer there) for £70 and programmed it with an idtool. Geoff |
24th Nov 2024 8:59pm |
