Home > General > Antifreeze?
andy vash
Antifreeze?
I’m thinking about replacing the coolant in my 2002 L322 4.4 V8. Can anyone advise in what type of antifreeze to use?
Post #77602 25th Aug 2011 6:26pm
info is on the wiki andy.. Thumbs Up
Post #77603 25th Aug 2011 6:27pm
dan_uk_1984
Make sure you do a full flush in between.
Fill with water, run for a few minutes, drain and then fill with the correct mix.
This way you'll make sure you get the correct mix plus dont have to worry about different types mixing.
Post #77615 25th Aug 2011 7:30pm
ukrangie
There is a list of lubricant specifications in the manual in your glove box. Paul
Twitter - Facebook
Post #79187 4th Sep 2011 5:35pm
