Home > Technical (L322) > 2007 3.6 TDV8 Heater issue
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Had a browse on older threads and I was just looking for confirmation, virtually no heat in cabin and decided it needed a look, is there another valve behind the pollen filter as well as the twin water control on the right hand side of the engine? I’ve got a brand new dual unit already in the photo I’ve posted to fit but do I need another valve? Many thanks _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #704430 14th Nov 2024 12:33pm
johnty
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Theres another valve under the plenum on the firewall behind the engine for the fuel burning heater divert...if this becomes 'worn' can also cause poor heating
Post #704787 19th Nov 2024 9:59am
Scottyav
I found that after and will be fitting them both Friday now , thanks for replying 😎 _____________________________________________________
Post #704963 20th Nov 2024 8:57pm
Scottyav
Fitted and red hot inside now all good 👍 _____________________________________________________
Post #705354 24th Nov 2024 5:04pm
