Home > Maintenance & Mods (L322) > 4.4 TDV8 front right side engine oil leak + vacuums
stefanstef01
Romania 2011 Range Rover Vogue TDV8 Zambezi Silver
Hello and sorry for bothering you,
On my LHD 4.4 tdv8 l322 I have found a oil leak from the right side of the engine ( under the throttle body intake pipe) wich drips to vacuums, belt tensioners and all over the engine.
During disassembly, I noticed oil vapors in the intercooler and some oil collected on the tubing from the small turbine.
I ordered all gaskets ( oil pump, oil cooler, egr, camshaft covers + new oil separator and new pulleys)
Any advices please? ( Is it possible to lose oil on the gasket of the injection pump? There seem to be traces of oil behind it as well). The oil level remains the same between oil changes but I have this horrible leaks. Also, does anyone have a diagram for vacuum piping?
Thanks in advice!
Post #704179 10th Nov 2024 9:34am
kevinp
What is the green tube?
Post #704183 10th Nov 2024 12:37pm
stefanstef01
vacuum hose
Post #704204 10th Nov 2024 6:10pm
