Home > Technical (L405) > Rear seats air vent. heating - 4 sone system - cold air… |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1404 |
There is a rear A/C unit in the left hand side of the boot as you stand at the tailgate looking in. It supplies air to the face vents in the roof next to the interior lights and the vents at the edges of the rear seat base area.
8th Nov 2024 11:25am |
JLS Member Since: 25 Jan 2016 Location: Oslo Posts: 23 |
Thx for a comprehensive explenatioin, fisha. Now I understand the situation. I have a small leaak of coolant, I guess from the coolant inlet to the oil cooler, since I can see coolant drops on the belly pan rear of the engine. I have bought all the gaskets for this job, including oil cooler gasket x 2 for the cooler and the turbo feed pipe.
8th Nov 2024 5:44pm |
https://drive.google.com/file/d/1aSE85XAUn...jS3Pd/view
9th Nov 2024 10:18am |
Thx for the Wiki-link. It was the same as I have downloaded before. But, the tip of searching a little bit deeper down in to the different folders was vital! The info isn’t Haynes quality, but sufficient 2016 L405 SDV8
11th Nov 2024 5:53pm |
Pugster Member Since: 17 Nov 2024 Location: Hinckley Posts: 11 |
Hi
17th Nov 2024 11:08pm |
Hi Pugster. I’m not an expert on the heating system, but it seems that you have an issue with airduct activators/‘flaps’. This beacuse you have warn air to one side. If you have an air lock in the back, it will result in cold air on both sides, and only effecting the air vents at the grab handles/puddle lights, and the vents where the back seat cussion meets the back rest.
18th Nov 2024 6:16am |
Thanks JLS funnily enough I got a low coolant light yesterday! I have a minor leak and top it up now and then so that may explain the front!
18th Nov 2024 8:02am |
Sorry, Pugster, not deeply familiar with with the in depht tech on the warmth distribution on the L405. I would get a fault reader, not the generic one, and see if that will pinpoint any fault air/coolant flap.
18th Nov 2024 8:54pm |
I've got the sdv8 - apparently it's a super common leak around the header tank or something else, a friend (indy specialist) says it a quick enough job I just need to get it up to him.
18th Nov 2024 9:14pm |
Yes, I have the same information: leak is common and ‘easy’ to fix… I’ve bought all the gaskets and sealing rings for both oil cooler and thermostat housing. I just need to find time and energy - just finished changing the rear differential… phuuu! Used 2,5 loooong days, included some rust fixing on steel components.
18th Nov 2024 9:49pm |
God knows what's round the corner!
18th Nov 2024 9:55pm |
He-he… cross fingers…
19th Nov 2024 5:36am |
Just to say thanks for your help JLS - swapped changeover valve and have heat.
23rd Nov 2024 11:51am |
