Home > Maintenance & Mods (L322) > Replace L322 Fuel tank breather pipe
Apache
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Anyone done this? Every time I fill full i get an overflow of fuel. I've dropped tanks on D3/D4 but never the RR L322. Is it a case of lifting back seats, disconnect hose and electrical connectors and drop tank?
Anything specific I need to know? Believe a new breather pipe is what I need?
I have a 2 post ramp.
Post #703328 28th Oct 2024 10:39pm
Apache
No one? It seems a common issue when I search?
Post #703634 2nd Nov 2024 10:33pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
don't know about removing the tank,
but to remove the underneath plastic tank guards, which i tried to do recently, i found i couldn't, i came to the conclusion that to remove them i would have to remove the rear suspension first.
i did have this problem, the fuel leak was where the fuel pump fitted in to the tank, who ever last fitted the fuel pump had not fitted it properly and the rubber O ring had fallen inside the tank.
it was easy to get to, tip the rear seats forward, undo the seat retaining hooks, take note of the fasteners, the spacers, and lift up the carpet, cant remember much else, but from there you might be able to see your leak
just noticed mine is an earlier model than yours RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #703641 3rd Nov 2024 4:02am
