Home > In Car Electronics (L322) > Wiring Harness Connector Blocks
flegg
2012 Westminster needing some TLC on its loom.
Specifically in drivers (RH) side footwell there are three large connector blocks all 40+ pins with corrosion
Anyone have any ideas where to get replacement connector blocks I can either splice in or replace completely?
Thanks
Post #703324 28th Oct 2024 10:16pm
RobsterPC
How bad is the corrosion? Could you clean the existing blocks up, maybe by de-pinning the individual connectors, clean and re-insert? Cutting out and wiring in a new block sounds like a recipie for disaster.
Post #703814 5th Nov 2024 3:18pm
flegg
I’ve already stripped and cleaned and bypassed the connector a few times for various faults
I’m not worried about the skill to do it as I do it for a living, just trying to find a similar connector block with the right amount in pins
Post #703865 6th Nov 2024 9:06am
