Home > Technical (L322) > transfer case subframe mounting insulation
Pal
Hungary 2010 Range Rover Vogue TDV8 Galway Green
Hello, I am after a small but irritating grinding vibration on my car, which tipically occurs under light load can feel it on the floorplate, footwell,gas pedal. Especially when the torque converter has locked up already. My first go to will be the engine mounts but would do these as well on the photo below.
Anyone has done the replacemet for the engine mounts or these subframe insulators? are there any aftermarket insulators available for this, do you know?
Post #702940 23rd Oct 2024 7:45pm
GraemeS
The part number is KQD500060 and I didn't spot any after-market versions.
Post #702973 24th Oct 2024 8:45am
Pal
Thank you👍
Post #702975 24th Oct 2024 9:03am
GraemeS
The prices are horrendous if per insulator but perhaps not quite so bad if a full kit.
I would be surprised if they needed replacing though as I expect the engine and gearbox mounts would deteriorate much more quickly, especially the variable-damping engine mounts.
Post #703023 24th Oct 2024 11:41pm
dhallworth
That will be per insulator, they won't come as a set.
Genuine Land Rover bushes are not cheap but they are very good and they do last.
When I rebuilt my old L322 in 2022 the rear subframe bushes were 75 quid each and there's 4 of them, each suspension arm bush was £50 and there was 14 of them. The car was totally transformed after I'd replaced every single one of them though.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #703045 25th Oct 2024 9:52am
