Home > Maintenance & Mods (L322) > TDV8 4.4 Primary turbo outlet hose access
JayGee
I suspect I may have a small boost leak but all the usual suspect areas are dry so the only other obvious place is the outlet from the primary turbo - is it accessible from behind the wheel arch liner or the under tray? 2012 TDV8 Vogue (L322)
Post #702917 23rd Oct 2024 3:26pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
The outlet of the variable vane (primary) turbo is directly connected to one side of the intercooler, if you want to check that connection too you need to remove the big tray to be able to remove the smaller tray that connects to the bumper, but first remove the tow loop cover, the one with the 90 degree coin clips to have access to all the screws. The front screws of the small tray are kinda hidden by the bumper, you have to bend stuff out of the way a bit to get to them.
If this doesn't give you access to the turbo outlet (never tried that one tbh) removing the wheel arch liner is the only possible way I would think.
Smile 2012 4.4TDV8
2000 Honda S2000
Post #702964 24th Oct 2024 7:49am
GraemeS
My recollection of what I saw recently of the hose with the wheel arch liner removed, I really doubt that access from below would be possible as the hose is above the sub-frame and engine mount.
Post #702970 24th Oct 2024 8:24am
JayGee
Thanks Graeme! 2012 TDV8 Vogue (L322)
Post #702984 24th Oct 2024 9:52am
