From the workshop manual .. would suggest you remove one of the rocker covers . . . . ( oh and you definitely have undone all 6 bolts ? )
REMOVAL
NOTES:
This procedure contains some variation in the illustrations
depending on the vehicle specification, but the essential
information is always correct.
This procedure contains illustration showing certain components
removed to provide extra clarity.
1.
Drain the cooling system.
Refer to: Cooling System Partial Draining and Vacuum Filling (303-03A Engine Cooling - TDV6 3.0L Diesel - Gen 2/TDV6 3.0L Diesel,
General Procedures).
2.
Disconnect the startup battery ground cable.
Refer to: Specifications (414-01 Battery, Mounting and Cables,
Specifications).
3.
Remove the right valve cover.
Refer to: Right Valve Cover (303-01A Engine - TDV6 3.0L Diesel -
Gen 2/TDV6 3.0L Diesel, Removal and Installation).
4.
Remove the oil filter.
Refer to: Oil Filter Element (303-01A Engine - TDV6 3.0L Diesel -
5.
Remove the glow plugs.
Refer to: Glow Plugs (303-07C Glow Plug System - TDV6 3.0L
6.
Disconnect the vacuum tubes.7.
Remove the vacuum reservoir.
8.
CAUTION:
Be prepared to collect escaping coolant.
Disconnect the coolant hoses.9.
CAUTION:
NOTE:
Remove and discard the seals.
Remove the engine coolant outlet.
10.
NOTE:
Remove and discard the seals.!
Remove the oil cooler. V8 or else ...
