Home > Technical (L322) > Rear height sensors |
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 |
New sensor will need calibrating, it will put the susp inactive fault on if you have not got it already if you change it.
25th Aug 2011 6:33pm |
Thanks, I spoke to LR yesterday and they confirmed this so I'm not going to change them just now |
25th Aug 2011 6:34pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
There is no recalibration option in RAC (yet) |
25th Aug 2011 8:53pm |
Shame |
25th Aug 2011 8:56pm |
Indeed. The heights shown by RAC are all over the place on mine but it still works fine. To be honest I'm not entirely sure if RAC is showing the correct values, they are so far out. The values it is showing do appear in the raw ECU message it displays though, but they are a long way off. One will show +400mm and another -132mm which is of course not reflecting reality. It could just be they need a calibration but if that is the case it doesn't seem to be bothering the ECU because it rises and falls correctly. |
25th Aug 2011 9:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
my values are out as well but not as much as yours ric, again i also have no problem rising .. |
26th Aug 2011 7:28am |
Took the FFRR out yesterday and was getting HDC Inactive, Air Suspension Inactive, ABS light and orange (!) light. This was the first time this had happened and when I had been working on the rear suspension I found one of the sensors was a bit suspect.
11th Sep 2011 4:04pm |
New rear sensors now in my possession and I'm just about to fit them.
13th Sep 2011 3:17pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
If your round my neck of the woods your welcome to use my RAC to calibrate the suspension. I'm on the Wirral so quite a way from you but the offer is there. If not maybe another member closer could help. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
14th Sep 2011 7:22am |
Thanks for the offer Rob but I would spend more on fuel than it would cost to have it calibrated up here
14th Sep 2011 7:36am |
Tut TuT Tut … Can't believe that someone who has a F K off garage does not have one of those |
14th Sep 2011 7:57am |
The problem is trying to get the right one that meets my needs |
14th Sep 2011 8:16am |
Buy both! Think the faultmate is the best but cost a fortune. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
14th Sep 2011 8:52am |
john, if you want to send one of your helicopters to collect mine ,you can borrow it to do your bits.. |
14th Sep 2011 9:28am |
