Home > My Range Rover > MY2019 SV Autobiography Dynamic |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 142 |
Very very nice! |
15th Oct 2024 2:31pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 |
Looks a peach Mike - MPx
15th Oct 2024 2:43pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16305 |
I believe I read somewhere that petrol 405's are not rated for roof boxes? Worth checking into sir... |
17th Oct 2024 12:08am |
Inigo Member Since: 15 Jan 2014 Location: Kent Posts: 33 |
I also heard that from the saleswoman at my first test drive. It made me panic a little, as that means Ski/snowboard runs are no longer possible and I should have kept the discovery!
17th Oct 2024 12:33am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
They are probably just covering themselves incase anyone does 155 mph with a roof box which I suspect wouldn’t be a happy ending! Just stick below 90 and it should all be ok - it’s a big thing to have on the roof at excessive speeds… 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
17th Oct 2024 2:40am |
Twas only making you aware as them Suisse & French Police can be quite clued up on Reg’s… The last thing you need on the side of the road I’m guessing… 👍 |
17th Oct 2024 8:02am |
Yes, OK, fair point, thank you. Perhaps I will try to find something definitive in case of a roadside discussion or, if needed, change my plans. |
17th Oct 2024 10:13am |
I've had a look at roofboxes, to see if I can find anything written down. Nothing in the handbook.
17th Oct 2024 10:38am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35454 |
the v8 petrol body should be the same as the diesel versions so i cant see what the problem could be...
17th Oct 2024 2:18pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 |
The only thing I've read relates to opening the roof with a box on, apparently you cant. Doesn't detract from the fact that you have a stunning car. Geoff |
17th Oct 2024 4:09pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2662 |
Very nice indeed , I’m a few weeks ahead of you ownership wise , they are mega .
17th Oct 2024 4:32pm |
I bought a boot mat secondhand from ebay, but it was the one for executive seats and with the bit that also goes in the cubbyhole on the driver's side. I think the part number is VPLGS0437.
17th Oct 2024 5:18pm |
