Home > Maintenance & Mods (L322) > Dpf - Cat delete question
NeilTDV8
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Asking for a friend, if you were to remove the dpf would you also remove the cat ? or could you leave the cat intact ? someone who does re-maps as said its best to leave the cat as it will stop a lot of smoke. What has others on here done ? This is a 4.4 tdv8 2011 L322. Thanks everyone.
Post #702128 13th Oct 2024 8:00pm
pcourtney
The best thing to do is delete the EGR ( this can be done any competent remapper ) , and then ask your local friendly exhaust company to cut out the DPF and drop it into a good DPF cleaning company
the last few posts on the page below throw a bit more light on the subject, this way you will not fall foul of any future MOT rules & regs, and also will be able to sell the car without having to disclose that you have removed the DPF or the CAT
https://www.fullfatrr.com/forum/topic71231-15.html
Post #702129 13th Oct 2024 8:31pm
NeilTDV8
yes going to have the egr deleted as well, i know it can't be removed but can be switched off.
Post #702130 13th Oct 2024 8:42pm
JayGee
Why does ‘your friend’ want to get rid of the DPF and EGR - more power or is it faulty? 2012 TDV8 Vogue (L322)
Post #702140 14th Oct 2024 7:25am
