Home > In Car Electronics (L405) > No Audio or video
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
No Audio or video
My audio system has completely died on me No Audio No Video No cameras. This happened completely out the blue. The only thing I have discovered is the FL 40A Audio fuse in rear compartment had blown. When I tried to replace it the new fuse blew as well. I removed the head unit as well as DVD player unit and tried another fuse. It blew as well now stuck
Anybody any idea what might be going on
Post #701222 1st Oct 2024 10:55am
It could be any of the components that have failed - but in my limited experience, amplifiers tend to blow fuses when they've failed more so than other components.
Post #701227 1st Oct 2024 11:44am
Kot
The Audio amp is under Front passenger seat, check for harness damage maybe, or water ingress! Do you have a sun roof?
Are you sure its FL40? 2018 SE SDV8 4.4 Byron Blue
Post #701233 1st Oct 2024 1:41pm
Pat
Yes it has the panoramic sunroof
Post #701296 2nd Oct 2024 3:20pm
I think Kot is thinking it may be this hopefully it's something cheaper.
Post #701300 2nd Oct 2024 4:05pm
Pat
Sorry its FL13 on rear fusebox
Its a 40a fuse
Post #701382 3rd Oct 2024 2:05pm
Gremlin500
Check the carpet under the passenger seat with a damp meter….. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #701388 3rd Oct 2024 3:23pm
Kot
Its a 40a fuse
That is the Audio amplifier fuse according to the drawing. 2018 SE SDV8 4.4 Byron Blue
Post #701410 3rd Oct 2024 6:28pm
Pat
Thanks
Thanks for that I will attempt to remove the amp from under the passenger seat and inspect it and wiring
Post #701730 7th Oct 2024 7:43pm
