Home > Technical (L405) > Rear door change - some issues…..
Bigfella70
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
Hi folks, swapped the rear nearside door on my 2016 MY L405 due to some damage to the old door.
Mostly gone to plan!
However the window will not activate from the switch on the drivers door and has been working intermittently from the switch on the replacement door. Unplugging and reconnecting the cable seems to help. Also the lock will not actuate.
The soft close function and the speakers work fine.
Suspecting the connections weren’t good I’ve tried closing up the spade connections within the block to no avail. There are some numbers on the block corresponding to different connections.
Please does anyone have an idea which connection corresponds to the window feed from drivers switch pack and also which corresponds to the central locking function.
I’m still suspicious that the connections are at fault however any other suggested welcome. For example does the replacement door need coding into the car for those functions to communicate with a different door…….
 Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
2004 Mercedes R230 SL350
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #700645 22nd Sep 2024 1:41pm
fisha
Do any of these help:
https://imgur.com/9xCPC8l
https://imgur.com/UiO9L8O
https://imgur.com/XeBjEUT V8 or else ...
Post #700656 22nd Sep 2024 4:06pm
Bigfella70
Thanks for the info…….sorted today. Swapped the loom and module etc from the original door to the replacement. Some slight differences and all working ok now Thumbs Up Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #700743 23rd Sep 2024 6:06pm
