Home > Technical (L322) > Light metallic rattle from rear |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1320 |
Heat shields rattling after aluminum hss rotted through at the bolt points
1st Sep 2024 11:47am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 413 |
As dingg1 says - The underbody heatshields would be my first point of call, they corrode at the fixings and become loose.
1st Sep 2024 12:16pm |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 35 |
Try the heat shield surround at the rear exit of the dpf. I assume there was once some heat protective material inside that wears away/breaks up and then this enclosure rattles. |
1st Sep 2024 12:25pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3059 |
Turned out to be the front OS brake shield which yesterday completely detatched itself. Quick fix with some repair washers and all is quiet again. 2012 TDV8 Vogue (L322) |
18th Sep 2024 6:42pm |
