Home > Maintenance & Mods (L322) > The importance of the correct wheel nut torque
JayGee
Had noticable wheel judder when high speed braking after a recent tyre change. I retorqued all the nuts and some were massivley overtightened and needed nearly my full 90KG on a long breaker bar to loosen them. Saw the fitter going round the nuts with a torque wrench but reckon they were just checking if any were loose after spinning them up with the air gun. No judder when I had retorqued them and after just having a front disk off to reatach the dust sheild I can see how overtightening will cause problems . The hub face is not flat and has an inner and outer mounting ring to mate with the inside of the disk so overtightening will cause the hub and /or disk to warp......
It's 140Nm for a reason and not crank them up by 'feel' with your longest breaker bar. 2012 TDV8 Vogue (L322)
Post #700348 18th Sep 2024 7:04pm
You're dead right, seen this time and time again.... mechanics, usually tyre fitters, using windy guns on the nuts with the car on a jack and then checking they were up to torque when on the floor. In fact they are seriously overtightened...
And god help you if you have locking wheel nuts and they overtighten them.... Rolling Eyes Pete
-Click here for Thread-
Post #700349 18th Sep 2024 7:11pm
