Home > Technical (L322) > Oil level
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Oil level
I checked the oil on my 4.4 and have the following in the picture does she require 0.5 ltr oil oil or more due to it showing less than halfway the site wouldn’t let me down load the picture 🤦🏽‍♂️. Thanks in advance Thumbs Up Thumbs Up
Post #700247 17th Sep 2024 10:49am
Rambles
Not sure what’s in the picture…but why not add 0.5L and then re-check level ?
It’s easier to add to these engines rather than remove if you don’t have a vacuum pump
Post #700256 17th Sep 2024 11:37am
JayGee
The oil level indicator usualy tells you how much to add. Better to put in a bit too much than too little. 2012 TDV8 Vogue (L322)
Post #700262 17th Sep 2024 1:00pm
DrRob
Re: Oil level
Was that with a cold engine or 20min post shut down? When cold, it should read 2 notches above mid way. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #700276 17th Sep 2024 3:39pm
Rambles
Personally i am in the “better a little under than overfilled” camp…
Post #700278 17th Sep 2024 4:22pm
Simran0211
Sorry for the late response it’s one notch under halfway. But it would take more than 0.5ltr to bring it back up I’ll give it a go thanks again 👍
Post #700292 17th Sep 2024 7:13pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
It’s 2 liters between empty and full on dash gauge. So adding 0.5L will get you a 25% increase to 75%, which will be fine. It doesn’t have to be full.
Post #700301 17th Sep 2024 8:54pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
The warning you get from the instrument panel when the oil level reading is over 'Full' is not something to ignore.
Sure, if you know it's only 1/2 a liter or less it's not going to be a problem.
In general, too much engine oil is not that good. 2012 4.4TDV8
2000 Honda S2000
Post #700652 22nd Sep 2024 3:13pm
