Home > In Car Electronics (L322) > 2004 54 plate RR vogue digital tv - is it really possible
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
hi guys,
im at my witts end tbh. I have spent almost 2 days reading up on fitting a digital tv unit into my 54 plate RR vogue that has a touch screen sat nav. It looks like there possibly can be a few options but no one says 100% this is what u need and this is how you do it. putting aside the option of buying a hybrid box, how else is it possible.
I have seen this on ebay with looks great:
http://www.ebay.co.uk/itm/Digital-Car-DVB-...27bd8fb7f0
but how would I get this connected into my car, what wires would I need and where would I connect it.
also what is the can bus i bus .... whatever bus. I understands its essentially the electrical network in the car but how would I know what mines is and whats the difference.
sorry for being a pain everyone, i just really want to learn... thanks
Post #76952 21st Aug 2011 2:54pm
easiest way is to by a hybrid box, but you know that already...the only other way i know is to get a gvif unit which effectively breaks into the nav screen most feed and gives you an input for reverse camera and a/v..with this you still have to get a tuner like the one in your ebay link..
what you need to remember is that all the hardware is in the boot and that feeds the screen at the front, so any aftermarket additions will have to go also in the back..
edit ..this might help you understand whats involved... http://www.disco3.co.uk/forum/topic49789.html
Post #76953 21st Aug 2011 3:07pm
RR8701
Hey scarey,
I have def seen your name crop a few times in the endless hours i have spend reading threads on this forum lol.
thanks for the info, its funny you should mention the GVIF thing because I came across that just hours ago on this site:
http://www.hids4u.co.uk/land-rover-discove...creen.html
is this what you were referring to ?
Cheers
Post #76954 21st Aug 2011 3:27pm
thats the one the disco3 boys are on about ...
tbh, i've thought about doing something to get digital in mine but the cost and effort involved outways the advantage of doing it..i rather spend �200/300 on a decent lcd for the bedroom ...
again, the best way is a hybird which will give you proper screen menus and i believe bmw and jag units will fit ,its just finding the right part number ..
Post #76956 21st Aug 2011 3:34pm
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
Hybrid Jag part number
PAG TV Hybrid
AH42-19C063-AC
BBU4A
94812
Thats whats on my hybrid unit anyways 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #76958 21st Aug 2011 3:40pm
RR8701
Thanks for the part number trafpol
I think the reason why I looked at GVIF box over a OEM hybrid tuner is because im limited with the original tuner, whereas with the GVIF I can other things, reverse cam etc etc
just need to figure out how to actually do it lol.
cheers all
Post #76961 21st Aug 2011 3:55pm
dan_uk_1984
PAG TV Hybrid
AH42-19C063-AC
BBU4A
94812
Unfortunately the 05MY (54/05) cant use the BMW hybrid tuner OR the later Jag hybrid tuner IIRC. They are a sort of crossover year.
Post #76962 21st Aug 2011 4:00pm
RR8701
dan_uk_1984 wrote:
PAG TV Hybrid
AH42-19C063-AC
BBU4A
94812
Well thats that option out the window, Rolling with laughter
Post #76963 21st Aug 2011 4:01pm
btw you can fit an aftermarket reverse camera to yours but it has to be 'switched' on in the ccf by some one who has an autologic or faultmate...
Post #76965 21st Aug 2011 4:25pm
RR8701
Ah right I see, do you have an example of a rev cam I could buy ? I dont have an issue with fitting it or wiring it through to the back etc but where would it plug in ?
Post #76966 21st Aug 2011 4:27pm
this might help..
http://www.fullfatrr.com/forum/topic6231.html
and the reverse cameras can be found on ebay ..the types that replace your number plate light seem the bestbut they must be ntsc ..
Post #76967 21st Aug 2011 4:33pm
RR8701
scarey wrote:
this might help..
that says for the pre touch screen. I have a touch screen ?
Post #76968 21st Aug 2011 4:35pm
first sentence says Hi all, I have searched but only come up with the pre touch screen info.
the rest of the post refers to touch screen...
Post #76969 21st Aug 2011 4:37pm
RR8701
Embarassed Embarassed Embarassed
Thanks mate Razz
Post #76970 21st Aug 2011 4:40pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
@Scarey...contraception is cheaper than an LCD TV!!.. Shocked .. Whistle Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #76977 21st Aug 2011 5:32pm
