Home > Technical (L322) > Normal rpm for 3.6TDV8 at 70mph? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
Tyre rolling radius (255/55 R19 or 255/50 R20) = 378mm nominally
10th Sep 2024 12:59am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Reading Paddy X350's post, I thought easy peasy, I will note my RPM at said speed later today and report back, as off the top of my head I have no idea
10th Sep 2024 8:04am |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 34 |
Thanks Phil,
10th Sep 2024 8:08am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
That does seem uneccessarily high for a big torquey V8. On the later 8 speed 4.4 it's around 1400rpm which likley accounts for the better economy and is a very civilised way to progress at speed. 2012 TDV8 Vogue (L322) |
10th Sep 2024 8:34am |
Completely agree. Although the top gear ratio is similar for the 6-speed and the 8-speed (0.691 & 0.667 respectively), the increased ratio spread of the 8-speed (7.05 compared with 6.04) allowed Land Rover to use a much taller axle ratio (2.76:1) in the 4.4 TDV8, producing a top gear ratio of 48mph/1000rpm compared with the 3.6 TDV8 6-speed’s 36mph/1000rpm.
10th Sep 2024 9:46am |
