Home > Maintenance & Mods (L322) > Driving with empty air reservoir?
AlexTVR
Heard a loss of air when driving, I think it’s my air reservoir as the tank looks badly corroded. Dash says normal height only available and it seems to be staying at roughly that height.
Is there a way to lock out air suspension (pull fuse) so car can be manoeuvred - it’s booked in for bodywork before the suspension can be looked at.
Not heard pump running, just a quick pssst when opening a door.
TIA
 2010 Supercharged
Post #699680 7th Sep 2024 11:49am
dingg1
Might help
https://images.app.goo.gl/ges7ir1ApfvQY7P98
Post #699682 7th Sep 2024 12:42pm
Merchy
this might help -
https://www.fullfatrr.com/forum/topic53950...workaround
Post #699705 7th Sep 2024 5:42pm
AlexTVR
Thanks for the link, pulled fuse 5 in rear box on my 2010 and that should disable things for the body shop work. Car has only lost about 15mm at rear over past week so fingers crossed. 2010 Supercharged
Post #699943 11th Sep 2024 6:10pm
