Home > Technical (L322) > Odd Instrument panel warning lights |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 774 |
Welcome to the best L322 place on the internet
6th Sep 2024 6:17pm |
STK79 Member Since: 14 Jul 2023 Location: Helsinki Posts: 5 |
Thanks for the advice, i will check that.
6th Sep 2024 7:09pm |
well now you have the LCM out, have you cleaned the PCB, they get corroded and fail, so carefully clean it with PCB cleaner and a soft toothbrush, do you know that the backup Odometer is part of the LCM, so a new one would need to be programmed up for your car
6th Sep 2024 7:18pm |
There is a guy in England who can repair your LCM if you cannot get it working
6th Sep 2024 7:27pm |
First Photo with ignition off
7th Sep 2024 5:35pm |
Second photo with ignition turned on
7th Sep 2024 5:44pm |
Thanks for answers.
7th Sep 2024 6:22pm |
Have you cleaned inside the LCM yet, there is a PCB which often fails if it is not super clean |
7th Sep 2024 6:42pm |
I have cleaned pcb, havent tried on car yet, there was some corrosion on pcb. 2002 L322 td6
7th Sep 2024 7:10pm |
Lcm dried in oven, now it works.
14th Sep 2024 10:16am |
