![]() | Home > Technical (L405) > L405 beset by engine problems? |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 498 ![]() ![]() ![]() |
he may be referring to the v6 issues that are widely reported to having crankshaft breakages.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1251 ![]() ![]() |
Buy Petrol |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
My understanding is that the 5.0SC engine in the L405s is generally reliable. Mine (Jan 18, 67,000 miles, serviced to LR schedule) has had no engine problems. Only Range Rovers since 1988 |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
I’m on my 4th V8 Diesel - all have been faultless 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 179 ![]() ![]() ![]() |
Wouldn’t someone who deals with maintenance and restoration, by definition be more prone to coming across problems?
Harrup Member Since: 01 Jan 2013 Location: Devon Posts: 29 ![]() ![]() |
Thank you all for your info - greatly appreciated. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1434 ![]() ![]() ![]() |
I have done 160k on a 5.0 supercharge and as long as you look after it its bomb proof, still going strong. I suspect he is referring to diesels in his comments. |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 211 ![]() ![]() ![]() |
Even the diesel V8's are very reliable if looked after. Lots of short trips can increase the oil dilution but this can easily be managed with more regular oil changes which are easy and relatively cheap to do yourself. |
Careeraxe Member Since: 12 Dec 2010 Location: Nottm / London Posts: 37 ![]() ![]() |
Sorry for reviving an old thread. Did You carry out any timing chain work and if so at what miles? My 5.0 is on 96k miles so unsure if I need to carry out any work. Thanks 2018 5.0 V8 Supercharged SVAuto LWB 2011 4.4 TDV8 Overfinch, black - Gone 2010 4.4 TDV8, green - Gone 2007 3.6 TDV8, black - Gone |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 ![]() ![]() ![]() |
I’m not sure who I believe less, politicians, used car salesmen, Putin or Trump - life’s confusing |
