Home > Technical (L322) > 3.6 TDV8 EGR pipe not lining up
dt2006
Ireland 2008 Range Rover Vogue TDV8 Java Black
Hi everyone I’m new to this forum,I have a 2008 3.6 tdv8 L322 which a mobile mechanic left in pieces and stopped replying to me,I fitted the new thermostat housing and hoses but I am now trying to connect up the metal egr pipes and one doesn’t seem to be lining up correctly and I can barely move it,the intake manifold is bolted in the right place so I’m not sure why it won’t line up.
This is my first time doing a big job like this on my rangey
Any advice would be appreciated thank you
Post #698836 25th Aug 2024 8:16pm
fisha
1) is it the right way round
2) make it fit ! Rolling with laughter
Seriously though … if he’s been that much of a div in taking it apart, he may have pulled at it when one side was still attached and bent it in doing so, putting it out of shape. V8 or else ...
Post #698839 25th Aug 2024 8:29pm
wayneg
Why not fit an EGR blanking kit and ditch those pipes, no errors will show and your engine will be happier.
https://www.ebay.co.uk/itm/375582574854?_n...BMyN_K5bFk 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #698849 26th Aug 2024 11:03am
Or you might be unlucky and the EML will come on once you’ve blanked them out (as happened on mine) and you’ll need to get the EGR delete remap. It’s not an expensive thing to do via the IID tool. Got - 2017 SDV8 Autobiography in Loire Blue
Post #698850 26th Aug 2024 11:48am
Tomo
United Kingdom 2009 Range Rover Vogue TDV8 Buckingham Blue
EGR delete map
Can you tell where I can get the EGR delete map as I have fitted the EGR delete kit but still get the Engine System Fault warning and loss of power.
Post #699319 2nd Sep 2024 3:38pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
You will need an IID tool, but the patch is done through Bell Auto Services.
https://bellautoservices.co.uk/store/rrs-3...-road-use/
Fairly stright forward as long as you follow all the steps outlined in the IID tool manual.
Will
Post #699320 2nd Sep 2024 3:47pm
Pawl
Tomo,
from my limited experience a couple of years ago, Bell Auto Services are not happy to provide modified ECU maps if the engine has fault codes that are current.
If you didn't know, their modified maps need a GAP IID diagnostic tool to install them or they can be installed by them or some approved garages that are approved by BAS.
If you've got a diagnostic tool, what is the actual fault code you are getting - ie what is causing the Engine System Fault warning you're getting. Presumably the Engine System Fault is displayed via the mini LCD screen at the bottom of the instrument cluster or is it via the Check Engine Warning Light ?
Installing an EGR delete plate won't remove any fault codes that a faulty EGR is creating as the EGR is still electrically connected to the cars ECU. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #699327 2nd Sep 2024 5:17pm
