Home > Technical (L405) > Brembo brake discs
mk1paul
United Kingdom 2015 Range Rover Autobiography SDV8 Causeway Grey
Brembo brake discs
I have just bought new Brembo discs and pads ready for fitting
BRE09.A773.11
https://www.gsfcarparts.com/za009154
Do I need bolts aswell? When I enquired about LR ones I needed to buy bolts
https://rimmerbros.com/Item--i-SYG000013?s...yOOdxvY5T5
Do I need to buy new bolts for Brembo?
Post #698608 22nd Aug 2024 1:57pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Get a fitting kit as well. You are bound to have problems with the pins. No need for new bolts just put a bit on Loctite on the originals.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #698662 23rd Aug 2024 8:34am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
The brake torque specs are for dry thread torque. As a word or advice to anyone who may not appreciate that Liquid loctite will raise the torque required considerably (as would any lubricant - hence a reason why you should never copper grease on a dry thread setup because you screw up torque setting). So, if a thread locker, is applied then ensure it has dried on the thread ahead of torquing the bolt. This would be your yellow or blue banding commonly seen on the threads of new bolts.
Post #698665 23rd Aug 2024 11:55am
Gremlin500
Exactly.
Just a word of warning for those not so technically minded, you can’t use ordinary loctite-type products, let them dry out on a bolt, then expect them to work, -they won’t. They are anaerobic, which means they cure in the [i]absence[/i] of air, you’ll have a damn long wait, then the product will just turn to useless powder when you screw it in.
There is a “dry” version: http://www.threadlocking.co.uk/loctite-dri-loc.html
But TBH, I (and JLR) prefer the accepted method of ‘dry thread torque plus given angle of rotation’, to “stretch” the bolt and lock the joint by elastic deformation.
I always use new bolts, especially on brakes, you have no way of knowing how many times they have been used before, is yours and your passengers lives not worth the cost of a few bolts? :whistle:
Post #698668 23rd Aug 2024 12:28pm
