Home > Technical (L322) > 4.4 TDV8 Restricted Performance |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Hi Brian
20th Aug 2024 6:41am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
My first question would be…..why on earth are you revving the poor girl between 3500-4000rpm? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
20th Aug 2024 7:31am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Pull some codes or log some data - anything without this is speculation. 2012 TDV8 Vogue (L322) |
20th Aug 2024 7:44am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3164 |
Inlet manifold? do a HIGH pressure smoke test.
20th Aug 2024 8:32am |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 121 |
It’s a 2012 if that helps re the comment about later models having an updated inlet manifold.
21st Aug 2024 3:34am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 807 |
Max power is at 4000 rpm
21st Aug 2024 6:07am |
You don’t need a license to read fault codes. 2012 TDV8 Vogue (L322) |
21st Aug 2024 8:08am |
I rarely take it beyond 3000 RPM, maybe once or twice per month. I think it’s important to give the car a chance to stretch its legs once fully warmed up. Being an old girl I am very smooth with all inputs so the run to 3500/4000 RPM is done progressively so as not to put unnecessary strain on her. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
21st Aug 2024 8:12am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2489 |
Mine gets up there occasionally when I'm wanting maximum acceleration overtaking in a short distance. Unfortunately speed limits mean that the run is very short-lived. |
21st Aug 2024 9:18am |
The last few times it’s happened it cleared itself following pulling over and turning off the ignition. I do have a OBD reader that communicates with Torque and this shows no stored fault codes. The same reader correctly diagnosed a faulty turbo actuator a year ago. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
21st Aug 2024 10:02am |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 99 |
I agree but the issue is where the hell can you use that oomph without hitting the legal speed limit 3 seconds after stamping on the fun pedal !. Just overtaking an artic on an A road means you nearly hit 100 by the time you get past , you have to be really careful overtaking 3 with a caravan on the back !!!
2nd Sep 2024 7:50pm |
For folks that think their cars are overpowered, and should all be artificially limited to national speed limits with no over-ride, the EU is coming to your rescue. |
3rd Sep 2024 6:07pm |
