![]() | Home > General (L405) > Westminster |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
You posted this in the L405 section….. assume you mean L322….. yes, it’s a run out model sitting between Vogue and Vogue SE spec wise. That said, it does have the 1200w Logic 7 HD hifi as standard fit.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
They made a Westminster P400e L405 , but I don’t have many details.
Ah, ok, my bad. Not as up on the newer stuff 🤣.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Weirdly, the Westminster had adjustable rear seats and the Vogue SE didn't, but the Vogue SE has radar cruise control and the Westminster didn't. I assume the Westminster also didn't have the cornering headlamps? 2015 Range Rover Autobiography 4.4 SDV8 |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 629 ![]() ![]() ![]() |
See this link https://www.fullfatrr.com/forum/post619191.html
28capridave Member Since: 08 Nov 2020 Location: stockport Posts: 28 ![]() ![]() ![]() |
i certainly miss my westminsters stereo system Quality system |
You have an L405 A/B? I have a 2015 L405 A/B now and the stereo system is absolutely superb, in a different league to the Logic 7 HD system in my old L322. 2015 Range Rover Autobiography 4.4 SDV8 |
Yes I have a 405AB but the sound system is not as good as the Harmon lardon I had in the Westminster I think in the AB it’s the 815W system but the l322 had the 1700W and was chrystal clear don’t get me wrong the autobiography meridian is good just not as good as my old westminster |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1454 ![]() ![]() |
Specs, including 2020/21 Westie, here - https://www.landrover.co.uk/content/dam/lr...427210.pdf 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
I’m talking about a 2012 westie not the 405 Westie re the sound system |
