Home > Technical (L322) > 2012 4.4tdv8 suspension red warning - drops to bump stops
RMac73
Afternoons- apologies for the vagueness - RR has suddenly started to drop to bump stops when going over 50mph - red warning message appears - if I pull over and reset with gap iid tool I get vehicle raising message and after a time the suspension cooling needs time message appears.
Anyhow here is the vagueness since I've cleared the faults I can't remember what fault appeared for the suspension issue but it was only 1 fault with algorithm mentioned in it - can anyone tell me how to use the gap tool to find out if I have a leak somewhere or if it could be the compressor itself?
Or is it a case of the soapy spray bottle?
Many thanks for any advice
Post #698000 13th Aug 2024 3:44pm
dingg1
Soapy spray bottle time, probably one of the front bags sprung a leak, you might be able to hear it.
Exercise the ride height and keep spraying
Post #698005 13th Aug 2024 4:39pm
RMac73
Cheers pal - that'll be tomorrow sorted then.... any particular atea? Or just all over bags and lines?
Thanks ๐Ÿ‘
Post #698008 13th Aug 2024 5:15pm
RMac73
Thanks ๐Ÿ‘
Post #698009 13th Aug 2024 5:18pm
JayGee
Raise it to off road height, pull the suspension fuse and leave it overnight and see whatโ€™s happened in the morning. If itโ€™s dropped itโ€™s got a leak. If not itโ€™s a height sensor issue. 2012 TDV8 Vogue (L322)
Post #698011 13th Aug 2024 5:54pm
RMac73
Thanks for that - another daft question- how on earth does the passenger fuse box lid come off? Handbook says pull down tabs at top but the tabs are at the bottom? Cheers ๐Ÿ˜„
Post #698019 13th Aug 2024 7:22pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Handbook is correct, looks like some muppet has fitted it upside down the last time they used it.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #698050 14th Aug 2024 10:47am
RMac73
Cheers Andy - yes it does look that way- will have another look today.
On a brighter note - doing a guided calibration with the Gap iiD tool seems to have done the trick with my issue. Ran through the procedure last night and took it for a run this morning - no beep and no red msg - so hopefully that is a win for now.
Thanks for all advice given ๐Ÿ‘
Post #698128 15th Aug 2024 12:00pm
