Home > Maintenance & Mods (L322) > 2008 RR SC Brake Flush Question
Steverebroker
United States
Hello Everyone,
I need to do a Brake Fluid Flush on this newly acquired Vehicle and it is my First RR.
Bought it from a good friend that got it with 161K on it...now has 203,500.
I am doing work with a mechanic Friend (who is unfamiliar with RR's)...but very mechanically knowledgeable....I am not.
Doing full Fluid Flush's on it...and planning to order the front and rear Differential and Transfer case fluid kit from Atlantic British with associated plugs rings etc....but wanted to do Brakes now as they are soft.
QUESTION:
What is the best fluid to use I can get at local stores without having to wait for mail etc...I read online any DOT 4 will work....Atlantic British recommends the ATE SL DOT 4....but I cannot buy local. Will LiquiMoly SL6 DOT4 work instead? Should I just use the Regular LiquiMoly Dot 4 instead? It seems to be the best fluid I have found locally...
Thank you for your time and shared knowledge!
Steve
Post #697738 9th Aug 2024 7:06pm
