Home > Technical (L405) > Deployable tow-bar troubleshooting help - gearbox failure? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7892 |
Have you tried spraying it with WD40 ? and maybe trying to pull it down when the motor engages ?
26th May 2024 2:36pm |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 89 |
I sprayed WD40 (or rather, something similar), on the lever for the socket for the trailer light connector.
26th May 2024 2:57pm |
By the way, the sound it makes when trying to deploy is something like this:
26th May 2024 2:58pm |
Powerful have a video for the L494 tow bar, which I assume is very similar. There may be some pointers in there ? (I haven't watched it all)
26th May 2024 3:16pm |
Thanks!
26th May 2024 3:40pm |
26th May 2024 5:50pm |
Thanks!
26th May 2024 7:04pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1366 |
They are known for seizing so that would be my starting point. Only Range Rovers since 1988 |
26th May 2024 9:43pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8065 |
IMHO deployable towbars are like locking wheel nuts and deployable steps, remove them all and throw them in the bin... all they do is seize up and fail just when you need them... Pete
26th May 2024 10:48pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 564 |
A bit harsh Pete! The alternative is a combination of regular use and regular maintenance (clean/lube) - works for me anyway, and I'd rather have them. Though obviously not the locking wheel nuts - they are just hopeless. Mike - MPx
26th May 2024 11:52pm |
My life is better without them... I'm sure if you lavish time and lube on them they last a bit...
27th May 2024 12:01am |
Thanks! Two follow-up questions: 1. What qualifies as regular use? 2. What components do you clean and lube, and how do you access them? |
27th May 2024 5:36am |
Well obvs the steps cycle everytime its locked/unlocked or a door opens. They get cleaned like the rest of the car (jet wash, snow foam, jet wash, two bucket sponge, jet wash, dry) probably every 3 or 4 weeks. I lube less often - Craig does it for me in the Jan service and I'll do it maybe one other time through the year. Its all of the pivot points in the brackets and the motor drive shaft.
27th May 2024 4:26pm |
Thank you!
27th May 2024 5:20pm |
