Home > Technical (L405) > Any shock absorber experts on here please? |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 454 |
Is the extra capacity a heat management solution? The extra thermal mass of the added fluid can more fluid movement through the valves without too much heat build up? First time FFRR owner |
23rd Apr 2023 6:55pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
It's nothing to do with heat.
23rd Apr 2023 7:03pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1415 |
@knwatkins:
23rd Apr 2023 8:30pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
I doubt that more extension is the reason as the fluid moves between above and below the piston as the shock extends and retracts. If more extension is required then a longer shock will be required.
23rd Apr 2023 8:41pm |
It’s actually for 3 reasons, I suppose:
23rd Apr 2023 10:44pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Thanks gang…
24th Apr 2023 8:44am |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 234 |
@Craig: what shocks did you replace them with? My 2013 needs new shocks and of course it uses different ones than most due to being that unicorn crossover year. It appears my correct part numbers are LR034266 & LR034271. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
30th Aug 2024 2:28pm |
