Home > Technical (L405) > Exhaust filter full visit dealer :(
Shadow_Dancer
Hi Guys,
Yesterday I did a long motorway journey to and back but mostly cruise control around 70 so probably 2000RPM or below. However 10mins from home it showed Exhaust filter full visit dealer and lost power so drove it home carefully. TBH I do mostly short trips with some longer motorway journey thrown in here and there.
I'm currently reading @KOT https://www.fullfatrr.com/forum/topic60839...t=dpf+full but its a long read and will take some time. Any advice in the meantime on how and where I can get this sorted would be much appreciated.
Thanks
Post #697313 3rd Aug 2024 9:36am
garyRR
Sounds like it's failed too many regens (various variables need to be true for it to happen, including temperature, fuel level, distance covered, exhaust temperature, speed etc). It probably just needs a forced regeneration.
But should also be checked for intake leaks. 2015 Range Rover Autobiography 4.4 SDV8
Post #697378 3rd Aug 2024 8:35pm
Shadow_Dancer
Thank you garyRR
Post #697380 3rd Aug 2024 8:39pm
Kot
Also get a OBD code reader some of them allow you to do a forced Regen and monitor live regens etc, anyway if there are sensor faults picked up from your device, then these will help pin point problem area. 2018 SE SDV8 4.4 Byron Blue
Post #697391 4th Aug 2024 7:18am
Shadow_Dancer
Will do thank you Kot.
Post #697398 4th Aug 2024 9:01am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Exactly the same thing happened to me after a long journey. The AA forced a regen and all was well but I haven't done a long motorway journey since. One thing that I did find was an almost completely blocked MAP sensor. Easy to take out and easy to clean. Not sure if it had anything to do with it but I haven't seen the Amber or red lights since.🤞. Get the Kot Kit and some valium and welcome to the society of soot watchers.
Post #697403 4th Aug 2024 12:12pm
Shadow_Dancer
😂 thanks Spridget
Post #697419 4th Aug 2024 7:19pm
