Home > Technical (L322) > 2006 L322 TDV8 battery drain - blower motor running
DaveKnell
Cyprus 2006 Range Rover Vogue SE TDV8 Stornoway Grey
I've a 2006 TDV8 with what seems to be a common issue - the blower motor runs continuously when the ignition's off, eventually draining the battery.
I've pulled all of the fuses that looked like they could have something to do with this - F12, 34, 52, 61, 64 and the damn thing keeps on running. I've had a good search but can't seem to find a next step.. anyone help?!
Thanks in advance --
Dave
Post #697226 1st Aug 2024 11:26am
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Sounds typical of FSR (final stage resistor) failure. There is a good write up re it’s replacement in the Wiki on this forum.
Post #697230 1st Aug 2024 11:47am
V8 Bob
Yes the FSR has failed only solution is to disconnect the battery to stop the fan then replace the unit. It’s a fiddle but can be fine at home. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #697235 1st Aug 2024 2:58pm
