Home > Technical (L405) > Global Opening/Closing without Sunroof
Rob99
Is there a way to disable the sunroof from opening when using the global open/close function on the keyfob?
When it's hot I like to give the FF 10 mins with windows open to get rid of some of the really hot air before I get in and use the AC. Having the sunroof open as well just makes it even hotter sitting in the sun plus I get bird poo and tree sap from parking under the tree on the drive.
The owners manual makes no reference to the sunroof but I have seen a US/Canada version of the manual which specifically says the sunroof is not included in the global open/close function.
I rarely open the sunroof so, if it's not configurable then maybe pulling the fuse will do the trick instead (assuming it's F10 and F12 as in manual) 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #697136 30th Jul 2024 1:43pm
